hey guys.
my engine light came on, so i took it to the mechanic and he tested the ecu. he said it came up with faults regard the coil circuit. i just wanted to know what that meant so that i can fix my car straight away. my mechanic didnt tell me anything else part from that. not even the error code.
thanks
https://www.sau.com.au/forums/topic/364413-rb25de-engine-light/
error code 21 will most likely be coil packs, double check that with the mechanic to see if it was the coils, also coils take about 2 hours to change with the parts so you should be good to go in about 1 day. if you have a non turbo like me, you might want to get 1 2nd hand coil pack replaced instead of 6 new iridium ones as that would cost u 600+ instead of about 200 bucks.
i've just rang him and got no reply!!! i just wanted to know what other things would be affected in the coil curcuit for the engine to come on. and yes its a non turbo. if it is the coil packs i was thinking of getting the yellow jackets coil packs? (anyone know if they are good)
cheers
  • 5 weeks later...
could be o2 sensor crank angle sensor or spark plugs, most likely coil packs
Would a faulty o2 sensor cause the engine light to come on?
i took mine (RB25DET NEO) to a mechanic and got the same code result,
He got the same code reply and changed a coil pack he thought was faulty and all the spark plugs.
i still get the problem, the car runs noticeably rougher when the light comes on but usually i can turn the car off and on
again and the light stays off.
The light can go a week or more without coming on and usually tends to come on when i take it easy and drive economically.
Thanks in advance
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
