does ^^^^ this mean our time frame has changed if you're taking your ecu out on sun?
When do you need mine?
Was gonna txt ya but thought its a bit l8
  • Replies 58
UPDATE OF WHATS STILL FORSALE
i have 2 weeks holidays so all parts are either off, or are days away from being off!!!
few price drops too!!!
HKS 25/35 turbo kit (direct bolt up to rb20, 25 and neo 25... uses stock dump, mani etc etc..) i have had braided water in and out made, stock oil in and dump. the turbo is 15,000ks old from new and is in IMMACULATE condition. $1500 FIRM with lines
z32 afm with pig tail loom $100
seimens deka 660cc injectors (black in colour and are not visible at all) these come with my stock inj loom with the req plugs soldered on, fuel rail spacers. these went in new when i rebuilt my engine, and have been used for about 4000ks of driving, they are not big enough to mess with your idle, but are big enough to push out much more than the 25 will ever hold. (note: these are only for s2 (rb25neo) $500
white dash backing bits, sticks to your stock one over the top, back lights up red, pretty kool i spose. $50
Autometer COBALT (search for pics and specs) but its -10 to 30 pound i think, blue lights, small and comes with a stand thing, it was next to my right knee in my stag and was very good (not too bright, not in the way etc etc) $60
nisstune ECU (worked with my car as auto and manual) as we know.. the best stealth ecu out by far! paired with my mods it was amazing!... $300 with your ecu (will need to do some research as to what ecu i really need... coz im manual now but may still need an auto ecu... and believe there may be a few) i will give this to you and once your tuned... drop off your stocker
tein type CS coilovers (suit s1 and 2 auto only) these are in mint condition and are height and 32-point dampener adj, they come with c-spanners, rebound tool and some stickers from new, and manuals,
$800 with my adj ISC toe and camber arms (10,000ks old)
s2 Xenon headlights, all factory set up plug and play, mine are in perfect condition, $300 firm no ifs or buts
Advan intercooler, no bent fins, fits up to stock set up, not return flow tho.... bolts up to chassis rails, quality is 2nd to none, ive used these light tinney chinese shit b4, and i couldnt believe i didnt go strait for the real deal! no cutting o the front side of the reo bar, just the underside so it sits flat, im sure i could actualy mount without any trim if u took time to play with it. $500
rear cargo blind in black, mint bar the drivers strut tower clip has a small crack, doesnt effect performance. $75
0400099986 is my number, txt only coz im at work mostly.
thanx guys
WILL POST ALL ITEMS BAR THE CARGO BLIND SA ONLY FOR THAT ONE...... all prices do NOT include postage
z32 sold
gauge sold
not worth selling the cargo blind
ecu i will sell for $250 and a sway for an RS4 SERIES 2 ONLY to any one in sa!..... if need be i could so somthing interstate.
coilovers $750 for a pick up in adelaide hassle free deal!
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
