Of prime importance is having no preload when you set them up. Find a level area to ensure equal height of each axle.
There should be an adjustment on the drop link to set up each corner. I have never installed a kit from scratch, only adjusted them once installed. from what I've seen they are a pretty easy install.
Hi B1, the best way to do them is on ramps. That way, when you tighten up the bolts on the link bushes, they are not going to twist when you lower the car down to normal height. If you don't have ramps, then you can jack it up. Just don't tighten the links bushes excessively and make sure you grease the side surfaces of the link bushes. They have nylock nuts so they won't come loose. Only use the supplied grease, as it is guaranteed not to affect the polyurethane that the bushes are made of. The most import greasing points are the large pivot bushes that the bars rotate in.
Hope that helps
thanks sydkid. ok heres what ive learnt sofar.
1. the car should idealy be sitting on an even surface (hoist or ramps) so theres no preload on the bars.
thats about it...haha
another question.....when i decide to lower my car, b/c the car sits lower and im sure some camber and stuff have changed....does this affect the swaybars?? as in would i need to re-install them after lowering it so its set to the new ride height??
cheers guys
cheers guys
Hi B1, not enough change to worry about.
Hi NRB, if the bushes were not lubricated enough then they would stays twisted and wear out a bit quicker.
It's not a major issue, but if you can avoid it, then do. If it's too hard, don't stress over it.
hey guys.......they finally arived yesterday. im abit stumped as to where everything goes. ive attached a pic of what i think how the rear swaybar should be assembled. am i right? are the washers in the right place? is everything in the right direction?? where do i have to grease??
the front ones just came with 2 urethane bushy things to replace the old ones. thats normal isnt it?
feel free to draw on the pic and repost it up:D:D
anyone??
well had a go at takin the front stock one off yesterday. was able to take one nut off the bracket that holds the bush but couldnt reach the other one that sits above and behind the radial bush/rod thingy. looked like i had to unbolt the that to get to the bracket nut. is there any other way to do this?? looks like i might have to take it to a mech afterall:(
Pretty much spot on, the large washer goes under the bolt head, on the outside of the bush (not between the bush and the bar). Grease goes on;
*between the bush and the bar
*around the bush in the eye link
*on the ends of the cotton real bushes where they go under and over the lower control arm
thanks sydkid. i ended up just gettin a workshop to put em on....now i think i regret it. i think they put the rear one on wrong. ive attatched a pic. it was done on a hoist. looks like they over tightened the nut up top and when they lowered it its twisted. also is the sway bar meant to sit on the inside or outside of the bush cause it also looks twisted.
love the way the car feels now...i could feel that it was alot stiffer pullin out of the workshop. cant wait for the next suspension mod.:):D
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
