Hi guys and gals,
I'm getting a strange noise from the gtr recently. It's developed over the last 6 months. It sounds almost like a solenoid clicking just once like a tick. It's coming from the front right of the car it happens whenever there is weight transition to the front. I've noticed it going over speed humps, coming in and out of my driveway (steep) also from things like if I'm driving down the freeway and the road surface dips. Also if im turning left and right. It only happens everynow and then ... well that I can hear anyway.
It's not something that a mechanic could really diagnose atleast without spending hours and hours looking for whats the cause. I was wondering if anyone here has experienced the same thing. I was thinking it could be a shock maybe. I have nismo s tunes that came with the car so I don't know how old they are.
https://www.sau.com.au/forums/topic/365239-whats-that-sound/
Then you should check your wiring make sure something isn't being triggered. It could be your alarm, my shitty alarm makes all these clicking noises. It comes from the shock sensor. Only happens when the car is off so maybe if it is your alarm, its failing?
I too would have initially suspected CV joints. My rears make a clicking noise when engaging gear and going over bumps n shit.
Hmmmmm
Best idea would be to borrow a friend to sit in the car and turn it so it makes the noise. While you look around the front and underneath etc trying to pin-point the noise.
Will make it alot easier to diagnose if you can see where its coming from.
My GTSt made a clunking type noise that turned out to be sway bar bushes but I dont think it would be that.
Noises are disgusting to diagnose, seriously. I just eliminated most of the noises from my car(most of them just being shit laying around/rolling around in the cabin) but now Ive got a f**king irritating sound coming from the passenger side. It sounds like a rubber/plastic and occurs over minor and major bumps and shit on the road. Mum was like just turn the music on, every car makes a noise just dont listen to it. That is true but when I know its there, I want it gone!
Might have to check out my swaybar bushes and links.
How loud is the noise? If its just a soft click i wouldnt even worry about it. If its a louder clunk then it could be upper arms worn. I had a clunk when turning left only on bumps, turned out to be my upper arms worn out.
Noises are really hard to diagnos, only this you can do is get under the car with a pry bar and check for movement in the bushes and joints, being a r32 most of the stuff is prob worn out by now, by the time a car gets to 20 years old all the bushes need doing really, I have an exploded rear subframe bush, was wondering wtf the sticky stuff was and then i found out there silicone filled pinch.gif .
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
