Time to give up my R33 nissan skyline , my reason for selling is that i have started flying lessons and need money for the lessons as well as cutting down on costs running two cars ! hence the sale. I am asking around $10,000 ONO. so if you have a reasonable offer i will consider, the car has just hit 127,000km has been serviced every 6000km with 10w40 full synthetic , diff and gearbox oils have been changed front tyres are about half worn with rears about 70% , recently just passed pink slip inspection (april) and just had disks machined all round fitted with Bendix general ct pads nothing fancy but there brakes with plenty of meat. Rego expires 3rd- october.
what car has done to it:
3 inch turbo back with split dump pipe , full stainless.
rays engineering SE-37s 17" very light with 235/45/17 a common size so tyres are cheap.
Front mount intercooler ( chassis has not been hacked the return pipe runs back underneath the cooler to standard piping looks nice and stock from up top).
turbosmart boost controller -10psi
been driven mainly as weekender with mostly highway kms i am the second owner in aus since it was imported 4years ago. the interior is tidy and have fitted a pioneer head unit with usb, aux in , and bluetooth no tears or marks in the rear seatslight tear on drivers seat and gear boot is worn but the rest is clean n tidy , the only gauge is for boost/vacuum.
For any more info please call me Elliot: *number removed*
Car location: Mona Vale NSW
photos will be put up this weekend.
have seen this car guys! very nice clean car, good luck with the sale!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
