What's wrong with yours Matty?
ABS and AWD lights come on upon start up frequently. In the middle of removing the centre console now to check the G-Sensor. The HICAS Light flashes once very quickly upon hard acceleration sometimes. I ran the car in HICAS Diagnostics and it came up no error. The HICAS pump itself is holding fluid above the max line (ignition on or off) and when the ABS/4WD lights are on i cant see any led flashing in the boot to get the error code.
That and one of my AFM's that drops voltage whenever it feels like it, makes me a sad panda..
  • Replies 3.6k
Posted Images
had same thing with mine matty...was G sensor.
Awesome, I was hoping the repair bill would be in the thousands! Anyone got a g-sensor for me? From a car that didn't suffer serious impact etc. ??
By the way Martin did you get home alright today? Jump starter pack man, gods gift to any daily!
Ha yeah no probs Matty! Btw I got a G sensor second hand in good nick through Grand Auto wreckers at lonsdale...
would have to be mid 13's im guessing
spot on u and damo 13.5 on the banger with a kick ass take off :thumbsup: 1.9 ish 60ft pinch.gif one of the harshest treatments of a manual car i had seen for the day i reckn but did it :unsure:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
