Troy sorry I missed your post the other day, I have used Kent brake and clutch on port rd they are very good and not that dear
Jenna sorry I have no idea for all I know its a high flow as he was saying to my mate for $1750 he could have the turbo and fitted so it must be a bolt on most Garrett require new dump pipes
  • Replies 3.6k
Posted Images
yeah steve @ racetech has a good reputation.
ash hobson at hackham classic perfomance dyno (chapman road, behind cottage lane) is good with skylines too, loads of good results, but probably not that cheap - drop in and ask for a price.
Jenna, Adelaide Turbo Services can make you up a GT30-based turbo with stock (fully ported) front/rear housings. Get a price from Bill Keen.
Andrew - with the SAFCII I would suggest to also add in an apexi SITC, so you can tune the air:fuel ratio along with ignition timing. Well worth it IMO.
Highly recommended :)
Willall is the go for all your tuning needs - no Disney dyno crap there - just no frills tuning that simply works. On a related topic - big thanks to Martin for tuning the tow rig, an excellent result!
Edited by Blue32
Jaustech at Holden hill are great if you're near that area. Anthony has done most of the work on my car and he definitely knows what he's on about, just have a look at his cefiro. Plus they're great blokes too
That's about what I get in my dead stock R33 GTS-T. In regular commuting traffic my fuel economy hovers around 10.5 to 11 ltr/100km, on whatever the pump 98 RON is I get. And that's with a mighty 128rwkW ;D
My economy is with it at 270rwkw, I actually got about another 50-70 k's per week by changing to a bigger turbo due to rarely being on boost
touch ur toes at ash'es but gets results
^^^ DOH! How many hours had he owned it when he did that?
2 and a half days. Might be a write off, a pillar is moved and floor is creased.
Supposedly he was just putting around and got t boned.
Considering I've already had 3-4 concerned phone calls from people asking if it was stolen recently, the young lad has been driving it hard.
So I doubt it wasn't partly his fault.
Steve Knight racetech in Lonsdale.
Has an AWD dyno too for any GTR owners down that way.
Def my pick for down south....more so for mechanical work than tuning........Troy, he'll be fine for your clutch change-over and belt replacement
ahhh, Martin told me he was going to tune the ZF in your Disco.......how have you found it compared to its previous tune and what gains did you make?
We gained 30+awkw to end up with 175awkw and more importantly gained 100% more torque - I'll default to Martin to share the results from the dyno........
As you know they are already quite grunty for a 4WD, but even more so now and it drives very nicely. Fuel economy should increase now too - test underway currently as I compare the usage on the current tank load.
thanks bud.....I completed a long trip with my Disco pulling a 3 tonne van and it did it every bit as easy as the LC200 which has an extra 1.5 litres and an extra 2 cyls :thumbsup:
Sequential turbo setup is what I'm putting it too (with the small primary and bigger secondary).....the new 3.0L is an awesome engine too......and doesn't burn oil like the LC200 either, LOL
Where is the meet point, and what time, matty? Maybe for me - got the kids, and me & the youngest have a bad cold.
Having said that, we're off in a moment to see Adelaide United vs Gold Coast with a mate.... my children havent been to a live sports match in a number of years (youngest was in a pram last time we went to a sanfl match) so it should be a good night, both kidlings are soccer players & are looking forward to it.
come to the T20 big bash on sunday brendan. even though i pretty much hate that form of cricket, i go just for the atmosphere, especially seeing as the redbacks win one every now and then
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
