hey guys and girls i own a HCR32 with the standard rb20det motor.
im planning a build on my rb20 looking at around the 260kw+ margin. i know the easier way would be to go with an rb25 but i like a challenge and i like the little rb20. just wondering if there is much to gain with a top mount manifold over a polished bottom mount? i presume that getting the top mount would cost extra as i would have to extend the turbo water/oil lines and make adjustments to the front pipe of the exhaust as well as the intake pipe and plumb back pipe from the BOV.. any tips are much appreciated :)
https://www.sau.com.au/forums/topic/365564-top-mount-manifold/
Roy has managed those results with a TD06 20g on an 8cm housing. The 8cm is only available in a 3 bolt housing and you will need a custom manifold for it.
An option I would explore is the 10cm T3 with a gate welded off the housing. I think this would get you the said 260kw without need of moving to a highmount manifold.
For that kind of power the high mount will sound nice but probably wont yield much of a gain.
No specific gain performance wise. Just easier to work on really, and you need to deal with the heat - so perhaps a minor hinderance (that can be fixed).
It's here nor there really - Just custom everything made up to suit relocation which is $$$.
Nice to be persistent/challenge, but RB25 is a better option realistically dollar for dollar.
at the moment its running a rebuilt and high-flowed r34 turbo but i am obviously looking to upgrade to something with a little more mid range response as the rb20 tends to get quite a bit of lag. only replacing the manifold because the previous owner has done some dodgy machining to the original one.
so by the sounds of it i think i will just hunt down a decent bottom mount manifold as a replacement and save the extra cash for something else.. anyone have any brands to recommend other then the ones sold on for next to nothing.
Edited by RBnub
i never said i didn't like the lag i currently run 230kw in my r32 and its definitely a laggy setup. :). i don't mind sacrificing a little torque for power since the rb20 has next to no torque anyway. having quite a large rev range helps compensate a little.
Stick with the stock manifold. Iron Cast is much better then these stainless steel pipes, they are much stronger and are far better handling heat. From personal experience I just got sick of having to repair my stainless steel manifolds so I went back to the iron cast and have not had a problem. The manifold will allow for way more then 260rwkw. If you really want want that extra 2hp you can always do some mold porting. There are tones of guides on here on how to do porting.
Wait till you get to 260rwkw+ then.
You need a tacho that starts @ 4000rpm :D
Haha yeah I bet But I still can't shake the feeling when boost creeps up on you In a laggy set up :P. Previously owning an r33 the extra torque didn't really amuse me much on the street.
Well linear power can be deceptive, and on the street is generally faster.
Remember 200rwkw on a R32 will feel faster than 200rwkw in a R33, weight, peaky setup etc. So totally agree there. It would potentially be faster too all things being equal.
However @ the power range you are talking about. RB25/260-280rwkw, pit it against a RB20/260-280rwkw - in the same car. It'll be difference like night and day :)
You'd be talking 500-1000rpm of difference depending on turbo choices, on/off throttle performance would be huge as will the power delivery.
You get more area to the right of the dyno graph, and thats what really is more important on the street. Less peaky setup = less wheel turning and more forward action.
Don't get me wrong - I've had an RB20 before, but it's tough to justify spending 1500+ on exhaust manifolds, plenums etc. You'll never see that value against performance as it's capacity & the head holding things back.
Yeah the head is the only thing holding me back on going through with anything on this car. Already having a Nismo high volume pump, gtr injectors, FMIC, Greddy type RS BOV, 3" exhaust, highflowed r34 turbo all working through a nistune might be easier to spend the money rebuilding a rb25 and whacking it In with a better ecu. From what your telling me an rb25 would see considerable improvement I'n my r32 then In a r33. I will have to look into what's involved In the conversion. Like a better gearbox for the extra torque ect.
  • 3 weeks later...
if you want a safe/reliable engine that pulls 260kw at the wheels every day whether its on rb20/rb25
you will need the following
Turbo hks25/35
minimum 3 inch exhaust all the way thru
stage 1 tomei cams and they mak a hell of a diff ,you dont need cam gears as hks turbo come on strong and on low rev
gtr injectors/hi flow your ones alot of preformance work shops hi flow them 650 cc
walbro fuel pump
z32 air flow meter
obviousley a computer and intercooler
had a couple of skyline did a lot of mistakes but again up to you what you want to do
if you need help getting any of these parts let me know i wil try my best to help
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
