I am going to try relocating my horn to a button on my dash, since after installing my quick release kit I cant get the damn horn wires and the actual horn to fit in its hole. Just wondering where I would find the wires so I can hook them up to a momentary button???
https://www.sau.com.au/forums/topic/365706-relocating-horn-where-are-the-wires/
Ummm aren't you basically answering your own question?
You said you can't get the horn wires to fit in the hole for your steering wheel. Then use that wire? Trace it back to it's postion in the loom and join into that
Well I cant use the ones in the steering wheel cause i cant loop them to the dash obviously. In the hub adapter this is one wire, is this a power wire? I guess i am going to have to take the whole boss kit off to get to the wire then.
Yeah easiest way to do it. Pull the steering column surround and steering wheel/boss kit off and try and locate the wire on the loom.
Run that wire to button. Earth the other side to chassis.
Do you have a photo of what the actual problem is? Not sure what the problem is that's causing it not to fit in the first place. Or is the horn button to loose?
EDIT: Ahhh never mind. Re-read the first post and it makes sense now. Hopefully won't be to hard to locate the horn power wire when you can see everything
Edited by 89CAL
Yeah thanks. The button just pushes on but there is so little room behind, the wires just spring back and push the button back out. Stupid quick release kit needs more room. I thought about not having a horn, but out of the 2 days of driving without a horn I dont think I could live without it since there are so many bad drivers out there!
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
