I am going to try relocating my horn to a button on my dash, since after installing my quick release kit I cant get the damn horn wires and the actual horn to fit in its hole. Just wondering where I would find the wires so I can hook them up to a momentary button???
https://www.sau.com.au/forums/topic/365706-relocating-horn-where-are-the-wires/
Ummm aren't you basically answering your own question?
You said you can't get the horn wires to fit in the hole for your steering wheel. Then use that wire? Trace it back to it's postion in the loom and join into that
Well I cant use the ones in the steering wheel cause i cant loop them to the dash obviously. In the hub adapter this is one wire, is this a power wire? I guess i am going to have to take the whole boss kit off to get to the wire then.
Yeah easiest way to do it. Pull the steering column surround and steering wheel/boss kit off and try and locate the wire on the loom.
Run that wire to button. Earth the other side to chassis.
Do you have a photo of what the actual problem is? Not sure what the problem is that's causing it not to fit in the first place. Or is the horn button to loose?
EDIT: Ahhh never mind. Re-read the first post and it makes sense now. Hopefully won't be to hard to locate the horn power wire when you can see everything
Edited by 89CAL
Yeah thanks. The button just pushes on but there is so little room behind, the wires just spring back and push the button back out. Stupid quick release kit needs more room. I thought about not having a horn, but out of the 2 days of driving without a horn I dont think I could live without it since there are so many bad drivers out there!
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
