31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 308
Posted Images
Take it to K mart James - Its freee!
Wonder how they make money of that .. all you see there are bunkies getting free checks lol
LMFAO!! I will be taking every f**king car i can to that damn place.. The one and only time i have ever paid to get a service done for me (i was working 70 hours a week while the mrs was pregnant so didnt have time) was at kmart. BIG MISTAKE. I got a service and needed two new rotors on the front and it cost me $1400 odd. I thought i was doing the right thing, and didnt want to hit my dad up to do it for me since i wouldnt be able to help him. pinch.gif
Needless to say if i can get some of my stolen $ back, i will.
Well ... you'll need about 14 check ups done to cover your costs
a normal check up at RAC/Midas .. one of those places cost 90 bucks
so if you do 14 you'll have covered most of the 1400 :D
James Nobody would fix anything at K mart! Besides bunkies perhaps ...
Plus theyd lose so much from all the cheap buggers like me who get them to do the check and then do stuff elsewhere
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
