So everytime i post (using the quick reply down the bottom) in the spotted thread in the WA section and occasionally in other threads i click post and get the following error:
An Error Occurred
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
[#10151] An unknown error occurred
under that it says my post data has been saved, but it all comes up in the topic anyway?
I dont think im the only one seeing this either as there seams to be a lot of double posts in the spotted thread lately. Everything works, the post always comes up, its just weird.
https://www.sau.com.au/forums/topic/366279-error-messages-in-wa-section/
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C)
Timestamp: Tue, 31 May 2011 23:55:50 UTC
Message: Object expected
Line: 400
Char: 1
Code: 0
URI: http://www.skylinesaustralia.com/forums/forum/14-ideasfeedback-bugs/
I'm getting this error on all sections.. Loads up to before the advert block and that's it..
well after using firefox.. i found that it was waiting on www.a.tribalfusion.com and ad blocker seems to stop it.. But that is also the adverts..
Hmm I'm not getting any issues and Im using Firefox all day...
Is this just localised to the WA section or not?
Seems its larger problem?
But then I've not had one issue, usually with such problems i notice it right off on my test accounts etc :(
only happens in WA section for me and almost always the spotted thread, the other weird thing is clicking the red icon on the left to go to the last unread post doesnt work only on the spotted thread, it takes you to 2-3 posts before the end of the thread, even if 100 posts have been made since your last visit. everywhere else works perfectly in that regard for me.
i'll get over it, just found it interesting it only did it for one thread.
edit: using firefox on xp if it makes any difference
Edited by JonnoHR31
:O I'm getting the same issue, could be some how stuck on something since the forum update. Could be a wayward sig or anything else.
Will try solution - make a new thread, please start using it and let me know.
  • 4 months later...
  • 4 weeks later...
  • 1 month later...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
