Nice work mate, well done.
Did you notice any real difference in power? I hear it makes very little power increase, and it's mostly just a better sound.
Wanted to do the same, but didn't think forking out $500 for a long ram cold air intake kit was worth it, would like to hear your opinion.
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-5850874
Ive seen this mod very popular over on the g35 driver forums. I always had the feeling that having the pods in front of the intake could cause some over heating issues as it blocked air flow as well as stole air the radiator would usually receive. But then again im still a newbie when it comes to these things as I have not seen anyone post problems about heating issues.
Nice work looks very clean, anyways my 2c
BTW not sure if you have any but im pretty sure this mod voids all engine warranty + if you have an at fault accident and have not declared this mod to insurance they can void your claim. Although I have not herd an insurance company void a claim due to a pod modification but when looking at this mod it does look significant in the eyes of an insurer assessor.
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-5856676
Took it for a run today, feels heaps more responcsive. Induction noise hasn't changed that much. By the way I didn't buy a kit I made it from scratch :D
Cool, make me one then :P
I had a quote from Stillen in the States for their Stage 3 CAI kit, item is around $US500, but freight from there is $US320. I laughed and never bothered with it after they told me that. I wonder if the ones off eBay are any good, kind of a bit sceptical with anything there in general...
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-5860152
The Stillen ones aren't that badly priced, To make these, a couple of K&N filters $160, couple of turbosmart 45's $60, couple of turbosmart 70-76 reducers $60, couple of turbosmart 76mm joiners $50, turbosmart clamps $70, couple of 76mm S/S 90dg bends $70, S/S tube & F/B $30. There's $500 just in parts without paint!
Then machine a couple of MAF adaptors, tig gas & wire plus labour nearly 8-9hrs.
So at my labour rate your looking at close to $1000!! Scary a!
I just do it because I enjoy making stuff.
So yeah, the Stillen ones aren't that bad after all :(
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-5862302
  • 1 year later...
Theres a thread over on G35driver where a guy put a bunch of CAI's on a dyno with no observable performance improvement, from memory in fact he got the best result from K&N drop in filters.
Having said that, awesome mod btw, looks great, wish I had the skills to fabricate something like that
I am not a fan of the Stillen intake cos you have to cut and modify the penetration from the engine bay. When I buy my CAI wich I probably still will, I'll go with Injen or Tanabe which don't require any cutting
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-6531433
I went with the SRI from R2C in the US. Couldn't be happier. Easy to install, black nickel looks great and it gives an awesome intake growl. Don't think that it adds any hp, not enough to notice anyway but if you want extra hp go with forced induction.
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-6531841
Guys, there aint nothing beat Injen with MR tech and K&N Typhoon. Tried myself the Injen, never regret. I ordered from the states bout ~320ish, fitted extra $50 (coz i didnt have my tool set Y_Y)...much more responsive, increase fuel consumption (only if u drive normal and not tempted of the tiptronic features lol )
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-6531860
I cant comment on outcome as didnt end up fitting mine, however when I was researching many forums favoured the stillen intake which is backed by testing and proven hp gains. Yes the larger hole is a pain, but they would have provided larger intake pipes for a reason.
I may be wrong but given stillens long lasting relationship with nissan, you would think their gear is very reputable.
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-6535494
I agree that you would have to think the relationship must stand for something, and I have read in most places that the Gen 3 stillen intake is the go, but the Greddy and takeda intakes are so dam similar to it that im not sure if it would make a difference which one you get lol
https://www.sau.com.au/forums/topic/366762-v36-cai/#findComment-6535923
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
