hi
i need your help
i sent my car in to a work shop to get my timing belt replaced over a months ago and also to get a greddy intake plenum done
the job was dont and they told me they needed to play with the tps settings on my ems 6860 and since them not been able to turn the car over
even with the base map
it waill turn and allmost start but just wont kick over
please help
https://www.sau.com.au/forums/topic/367051-ems-ecu-6860-help-car-wont-start/
ah ok thanks
thanks for the fast replys
its just been sitting in there now and being in wa there not much places i can take it too
they told me the car was starting at first but lumpy but now after playing with tps nothing
iv been there and put stock tune on it but no luck still
keeps turning and drains battery very quick
i have pluged to two at one to stop this
please not has stroker and after market injectors and turbo if that makes a diff
Bro I've got a stinger. I know all the EMS ecus have a clear flooded function, so when the tps senses 100% it wouldn't fire.
Is the tps set up properly? The signal could be negative?
Try disconnecting the tps? take a print screen of your ecu settings and fuel map and post it here! Il have a look compared to mine...
Edited by StealthX
i sent my car in to a work shop to get my timing belt replaced ... and since them not been able to turn the car over
... it waill turn and allmost start but just wont kick over
Check that the cams haven't moved during belt reinstall process. One tooth out on the timing gears will make a massive difference.
Surely the workshop that performed the work is looking to correct it? If so what is their diagnosis and fault finding plan?
problem solved
when they played with the tps settings some how the ignition point was set to 1 not 6
as the stock ecu uses 1 ignition point (the black box on your coil line )
its running lumpy now but they got fuel injection (ems) on the phone Friday to get it running good
thank you for all your help
and special thanks to Room42 for the personal help
Edited by r33pmysta
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
