Hi guys I'm sort of new here but old the 240K scene, my previous account not valid or I've forgotten it....anyways.
Few things for sale,
Complete race prepped L28 N42 head for sale, bought last year from an ex Z racer, been ported, polished, race spec cam, etc etc, don't know specs, sorry.
Have an L28 F54 bare block, over bored .030 with torque plate, dipped, professionally done.
The head, block & extractors all purchased from ex racer, trustworthy guy who assured me all in very good order. I've checked over, no reason to believe otherwise.
Z extractors, won't fit K's, solid, good order.
L24 engine, runs OK, minor assembly req'd $50
Price on head $300
Price on block $200
Price on extractors $80
Weber 40DCOM sidedraft carb on Lynx L6/L4 adaptor, brand new, used once as trial fit, removed for RWC, never used again. Fit's on standard C110/210/240C etc downdraft manifold.
Get it jetted to suit, cable/linkage set up and you're good to go. Paid over $800, sell $500.
If anyone has a good working set of 240 SU's and manifold they'd like to swap for anything, let me know.
Located Cranbourne, VIC
Email at [email protected] or call 0423 905 546, cheers
  • 4 weeks later...
Still for sale, price drop
Weber 40DCOM sidedraft and LYNX adaptor, suit L4/L6 will sell for $400 obo
L28/26/24 Z extractors, will sell for $70.
L28/26/24 professionally balanced & lightened flywheel (ex race), complete w/ring gear in good condition, light surface machining req'd. $100
240K dash guages; temp, fuel & clock only. $40
Call 0423 905 546 James
Hi James,
Still got this? Wonder how I would go carrying it onto a flight back to Sydney...
Darryl
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
