Sorry guys, been flat out with other nonsense.
So far the following things are gone -
* Trim around the steering column
* Turbo
* Power Steering Rack
* Stock coils
* Ignitor
The rest of the car is still there. Plenty of other bits to go!
  • Replies 93
Posted Images
hay mate im keen on the wheels can u please email me at [email protected] or send me a txt or call 0438307579 as im not on here often m in geelong i can head down whenever suits to pick them up but i need to know asap chees mate ,. rick
* Gearbox and related stuff (for a conversion) gone
* Driver's side door gone (just the door itself and window/motor mechanism) - still have door card, electronics, door handle and key
* Turbo
* Stock coils
* Ignitor
Don't forget i've also got the splitfire coils - asking $450. Still have the box they came in!
Hey there mate,
sorry to hear about the accident. I am after two things: I need the LHS passenger air vent and i need the panel in the boot that goes through the rear seats in good condition i hope.
Update - Stuff that's gone so far -
* clutch+gearbox+tailshaft etc for manual conversion (still have flywheel)
* passenger seat belt
* interior mats
* 2x injectors
* Turbo
* Stock coils
* Ignitor
* Driver's side door gone (just the door itself and window/motor mechanism) - still have door card, electronics, door handle, key and mirror
* Passenger side vent
* Headlight switch
* centre console tray holder thing
* fuel pump cradle (pending payment). Still have fuel pump
* front seat buckles (pending payment)
Plenty of car left and those splitfires!
* interior mats
* 2x injectors
* Turbo
* Stock coils
* Ignitor
* Headlight switch
hey mate is that centre console the plastic trim that goes around air-con panel, and shifter? If not I would like it.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
