  • Replies 163
Posted Images
It's at the end of The Hume Highway where it splits off into Cambelltown road and Camden Valley Way. There's a Bing Lee near it, hard to miss
Hey is there an address i can pop into the GPS that will take me to the meet up point? I don't know my roads well around that area.
[EDIT] The meet up point is at the KFC on the Corner of Beach Rd & Parkers Farm Place right?
Edited by choongy
Haha dont worry i aint like the other 17 year olds, mummy or daddy didnt buy me a skyline for my birthday. I worked and saved for it, so im gonna look after it.
I'll be on my best behaviour :D
Of course youre welcome. All are welcome. Thats what its about. Just gotta love your cars and great company and your good to go:)
decided to bring the 200 out again... for anyone already down south, we'll meet up in front of the school next to St. Paul's catholic church along tongarra rd again.. Wont be the same without owen banana.gif
Sounds good. Do you wanna PM me your number so i can keep you up to date with the syd people if there any delays ect?
Just been in discussion with 'wannabedrifter' and we will leave cross roads at 10.30am sharp so we can meet up with the guys from sth coast in time. What time, i dunno, check with 'wannabedrifetr'
Thanks
Hi guys. The meet up for the south coast cars will be on the corner of Illawarra Highway and Macquarie Street. Lets plan to be there by 12pm. any questions just pm me. cheers
Gem you have to change your pic hope you kept something from the princess
Hellya!!! I kept the pink seat covers as my mascot the lil fairy that hangs from my mirror:) I am sad that i didnt get a turbo but i needed to think $$$$ and the GT was just outta my reach:( Don worry thou, when i win the lotto ill give Terry a run for his money:):)
I'll be there too.
Gonna be @ Cnr Beach Rd & Parkers Farm Place, Casula NSW 2170 @ 10am on July 2nd. Can't wait!
I drove through Royal National park all the way past Bulli but I never went past the Gong. I'm looking forward to a nice chilling cruise with respectfulness and turning corners really fast :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
