Hey guys just thought i'd list my pride & joy for expression of interest as i'm wanting something different for drift, will be more then happy to sell the rolling shell for the right price as i'd rather put the running gear (e.g engine, gear box, ecu & loom) into something more suitable for drift
So as you all know its a hr31 passage gt 1988
All mod plated for the 25 conversion with rego till the 10th month
Rb25/30det made 306hp on 14psi, engine still has alot hp left in it, as the turbo is out of flow "maxed out" if you where to wack a garret gt3076 or gt35/40 turbo on it will crack over 400hp easy
Tuned by EFI performance
Wolf 3d v4+ computer with hand controller
Tdo6 turbo with high-mount manifold
50mm external wastegate with screamer
2 stage boost controller 8psi & 14psi
The head is series 2 rb25det turbo head with an internal oil mod to run the VCT
JD customs forward facing plenum
Xf throttle body
550cc injectors
super spark coilpacks
mild head work & porting
Hks multi-layer steel (MLS) head gasketThe rb30 block was built by ERD engines in brisbane
Arp head studs
ACL race bearings
Genuine nissan piston ring kit through it
Arp con rod bolts
Balanced & cyro block
Gtr n1 oil pump
Crank collar
Chemically cleaned
52mm radiator with thermo fan
Front mount intercooler "600x300x70"
full 3" inch exhaust system from turbo back
Oil cooler with oil relocation kit, easy access to oil filter
Series 2 rb25det 5 speed manual gear box
Exedy heavy duty clutch x2
Custom 2 piece tailshaft
R200 diff "LSD" diff gears are 4.375 (might be a 2way but not 100% sure)
Bosch external fuel pump with holly lift pump into the 2L surge tank
Fuel regulator
Battery relocated to the boot (new battery)
S3 front end, "turbo" ti grill, projector head light
Afterburners with "turbo" garnish
MDU coilovers all round s13 conversion up the front with 8kg springs, 10kg springs in the rear
Passage blue interior in great condition
Comes with a set of 16" inch rays volt racing wheels
Hicas has been removed & bushes have been put in place
Turbo timer
Jvc head unit with kicker 6x9's & 6" alpine's in the front
Overall this car is in awesome condition, the 2 front guards do have some small damage but i do have 2 new ones to replace, just need to be painted
Asking around 10k
I got loads of pictures of the build so if you want anymore just request what you want.
Any questions please just ask, fell free to come check it out
Located on the gold coast
Cheers luke
https://www.sau.com.au/forums/topic/367652-306hp-rb2530det-hr31-passage-gt/
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
