No commercial stake in this (although I'm racing in the series this year). Just an interesting option if you haven't raced before and don't want to pay.....
http://www.chanceofalifetime.com.au
Basically, pay up, you get one day timed sessions at Wakefield. Person with fastest average lap wins.
I'll be going to the 24/10 session as Kelly is entering that day, and am happy to help any other SAU ppl who are interested in giving it a go.
Ive seen that advertised in autoaction and talked about it with other people who race karts, is seens a bit dodgy to me, think about it there are so many things that affect lap times temp, tyres etc and also if you have raced/driven a particular type of car you are abviously going to be quicker that someone who steps in even if they are a better driver. Bit of a gamble to me.
true, they try and keep it even by
5 * 5 lap runs in each of 5 cars
Drop slowest session (if you stuff it)
Tyre pressures can be adjusted
Only get compared against others from your day's heats (to rule out day to day temp changes)
And the Daewoo one is for novice (non-CAMs license) only.
I ran this the other year, seemed fair as it could be to me, and I highly recommend it. As for karters, all three who won a season last year are ex-karters...
How did the person who won the konica drive go?, the others dont really lead anywhere but would be fun to do. I dont think you would get the best equipment, personnel etc which dosent matter for the one make series but would make a big difference in konica. I heard all bad stories about the guy who won a formula ford drive through the kartstars and a free drive cost him a fortune.
The bloke that won the Konica drive was Grant Johnson, running 10th in the series. You're right, it wasn't the fastest car out there, but it was still a free season, and 10th is pretty good in a series that competitive. They're planning on buying a new car next year too, as all the top V8 cars will be replaced due to the new regs.
The other two who won last year are:
Ben Morley, 3rd in MGs and
Robert Dercole, 1st in Daewoos.
As far as costs, its just damage to the car - it cn add up if you're not careful, I'm paying on average $500/round for that.
:D
  • 3 weeks later...
Hey Pete,
If you read this can you PM me?
We're heading down for COALT on Wednesday night and looking to get a cabin at the place next to the track (Pelican Sheep Station). I think the deal is 4 people stay for around $60, so let me know if you want to shack up with Duncan and I.
Kel
Originally posted by Kel
Despite having heaps of fun, the best I managed was a mid-field finish.
There was the small matter of overtaking all three cars in the first session though.
Zoooooooooooooom.
"Where the hell did she come from?"
:eek:
(PS no-one lend her your keys - I now know how she treats borrowed cars)
Hey Flip,
You might be too late. check out http://www.chanceofalifetime.com.au, I know they have already started the trials, but I think there is one more in December
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
