we've all wasted money on cars over the years,spent many hours only to have sold the car at a later date at a huge financial loss.....old classic cars always hold a good dollar so this time im rather excited with my current purchase,this genuine 1975 mazda GT rx3....I bought old granddad mazda from japan and he has had quite a few nasty paint jobs over the years,although he is in pretty original condition.So here he is just arrived ready for his return to youth make over.....its getting stripped to a bare shell,bead blasted underneath/inside and outside,repainted and fitted with a period correct mazda factory racing 12a peripheral port engine,although it will have throttlebody injection hidden underneath the standard aircleaner :).....now old pops would have been a bit of a stud in his day,being mazda's "sportscar" of the seventies,the RX3 gave a shake up to the gtr in the japanese touring car class spoiling nissans chance of 50 wins in a row and for some reason appears to be the most desirable model.....so here is a bit of nostalgia for the younger guys to show them it wasnt about how loud your stereo was,how bright your neons are or how silly you can make your car look with 50 inch wheels.....it was the begining of the era that got the boys with V8s worried and taught them the meaning of respect and killed off the term "jap crap".
https://www.sau.com.au/forums/topic/367749-mazda-rx3gt-restoration/
  • Replies 89
Posted Images
Please please please don't put simmonds rims on the car...like every other Capella/RX2/808/RX3 out there
I love these cars
PP 12a will be awesome!
i think that when these cars are built up to keep with the theme of old mods simmons are something that was used in the old days so to make the car period correct they get used.....or those old jelly bean wheels/dragways....its not like you can put newer wheels on .....i dont think there is much choice
ok heres the rear seats back after retrim.....someone had changed the front seats over the years so had to find those(found now) and they are still getting done.....75 GT's had these funky washers in the centre insert and leather was also an option which the owner took on my car....Im also about to build up the factory race engine with a bunch of new old stock stuff i got here....i will post the pics when i get going on it
I can't believe for the same money I paid for the GTR 8 years ago I could have bought 3-4 RX3 coupes. Now good luck getting one for a reasonable price let alone finding one.
Nice score. Will be fantastic with period mods and a nice 12a PP!!!
Can I ask how you sourced the car in Japan? Aren't the locals buying these up as well so finding one for export is difficult?
yep hindsight is wonderful huh?I do know of 2 other GT rx3 coupes in japan for sale (one of which i painted over ten years ago!) and familia coupe (r100) so they are around and for sale.
I look around here and found nothing but 808's converted into rx3's with autometer tacho's,roll cages and autobarn race seats for no less than 13k was the very cheapest....on the other end 30k for gen rx3 but with again roll cage/turbo engines but nice cars....just not original/period correct....im about to start building the engine....for those that dont know these first pics are the "engine cylinders/block and camshaft's" all in one and these are mazda factory racing units.I will show some pics of the engine being assembled as i go
mazda factory racing inlet manifold and injection throttle body.The throttle body is a direct bolt on to any manifold that takes a webber/solex carb and converts to efi.I dont think i will be using the trumpets as they dont really fit the era of the car
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
