Bit of an interesting one here.
Car starts up first time every time on a freezing cold morning. But if you drive the car and turn the car off for a short period of time it just wont start again. this isnt really an issue most of the time but if you duck into the shops for a minute, you have to wait about 10-15 mins before the car will start up again. Car has only started doing this since all the parts were put on and tuned. plugs have been gapped down to .8 from 1.1, brand new battery (550CCA) .
It cranks and cranks but just doesnt fire. any one have any ideas?
car always started fine with nistune and usual bolt ons. now has Z32, bigger injectors, pump. All of which were brough brand new
anyone care to hazard a guess at what it might be
thanks
https://www.sau.com.au/forums/topic/367767-car-wont-start-when-warm/
was advised to gap down to 1.1. this didnt make a difference at all.
Im unsure if the ecu was tuned for hot/warm starts. It does it that randomly thats its hard to say/
car only makes 270rwkw. so its not that.
Hasnt done it since i popped this thread up. even with a few short trips to the shops today. which was nice
Intermittent problem starting when car is warm - exact same problem happened to me in my 300zx (z32 TT).
Does yours stink like fuel when it's trying to start and occasionally run like s--t? Mine did.
Problem turned out to be the coolant temp sensor - actually, the sensor itself was fine, the wiring just near the sensor had corroded.
The coolant temp sensor was intermittently failing.
When the car was cold it was fine, because the ecu thought it was cold. WHen the car was actually warm, it would basicaly attempt cold start up and dump heaps of fuel in.
Because the sensor would work intermittently, sometimes it was fine and sometimes not. At first, it would struggle to start, but then be ok. It deteriorated until it became a problem when running.
Cut out the corroded wire, reattached to the sensor, and it was all fine.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
