bud you contacted me on my want to buy post
Im guessing the reason you took so long to send the money and send the turbo back was your memory is bad... It all started with you so stop trying to make out it was my fault!!!
Sent 16 May 2011 - 07:04 PM
hey mate just wonering if youd sell the good turbo for $150 to victoria
The reason your getting flamed is quite simple... Your a idiot its not because you can't spell its because you are a scammer.
The whole thing was because you kept the turbo and would not respond in a reasonable time frame. If you think 4 months is reasonable IM sorry ill take back everything. You received my turbo which was in perfect working order that was taken off my skyline. You then said it would not fit because it was not standard, you then said your mechanic said it would not fit which to me sounds like both you don't know what you are talking about and when that failed you claimed there was a oil leak. All this time I did not argue with you even though the "not fitting" thing was a total load of bullshit, you then said it had a crack in the oil line and you were not happy with it. You received a refund within 5 hours with no complaining and with several apologies for the inconvenience in the mean time. You were the reason this went down the drain and ended up viral on the internet. Not because of me it was because of you I did everything on my end to ensure it went smoothly, If I sent it faulty do you really think I would agree and send the money back so quick?!?
In the end your reputation as a skyline owner has ended in tatters with no one on sau ever going to do business with you again and infact everyone here has actually got a bit of laughter out of it with your stupid non grammered comments. On receiving the turbo back its clear you did not look after it and in my professional opinion as a refrigeration mechanic who deals with welding, holes and abrasions on refrigeration piping the hole in the oil line was clearly created by bad handling probably from being tampered with in a attempt to keep it claiming it was faulty before realizing your dealings with me have ended up on the internet.
At the end of the day you have lost and I can guarantee karma will get the better of you in one way or another for the way you have treated me.
Thank you for wasting my and everyone elses time and i thank everyone on sau for your ongoing support. RYAN LOWE if you do continue to dig yourself a hole i am more then happy to provide chat logs and pics from both sau and my phone for you to use as a shovel.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037582
  • Replies 98
Are you even sure its YOUR turbo he sent back to you? Wouldn't be surprised with this douchelord if he still has your turbo and sent you back his dodgy one.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037597
I said a hip, hop a hippy a hippy to the hip hip hop you dont stop a rockin to the bang bang boogy said up jump the boogy to the riddim of the boogity beat.
loookseei eyes kan tork lyke tranzgender tu
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6037749
couldnt give to f**ks what ya do.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/5/#findComment-6040959
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
