Les Lothringer's post-81011-0-85832000-1308310443_thumb.jpgApproach to:
- - Resetting Flashing Airbag Dash Light on Nissan Skyline R34 - -
Refer picture for text description.
I applied this method on installing the Airbag after replacing the Steering Wheel [refer separate post for that procedure].
I have never had an Airbag Indicator Flashing Issue when the battery only has been disconnected, even for a few days.
If this procedure does not work for you, do let me know.
___________________________________________
Finally, due to the proliferation of pathological lawyers and the people who use them, the usual Disclaimer of Responsibility.
- Disclaimer: This describes my approach. If you choose to follow it and screw it up following this approach, remember - at all times, it's your fault. If you choose to follow it and get a different outcome, that's because you need to know more than what is described here. No responsibility for errors or ommissions. Every car can be different. No remarks made on the safe handling of airbags.
https://www.sau.com.au/forums/topic/368109-r34-skyline-airbag-reset/
an r33, but i've tried it on a 34 with the same problem, flashing and continuously onseems to donate different problems.
its the same method to fix a flashing airbag light as described in an r33,
for an airbag light thats permanently on, i don't know what the fix is, no error comes up on a consult scan. :/
OK - Why not give me a call & we'll talk about it.
Les . . . 0417 123 053
_________________
tomorrow maybe, - when its light outside. On my car, its been in an accident, (before i owned it) not sure if the airbag went off or not, if it did, then its been replaced. Either the computer won't recognize the new airbag, or its not been plugged back in correctly/ wiring problem.
i wanted to go poking round and look for the cause but i'm too afraid of accidentally setting off the airbag.
this is for an R33.
The method I described is for an R34. You have an R33.
I have seen a method, described for an R33 and claimed to work on an R34 - it did not.
Each model has a unique method. Some are just plain ridiculous.
Re setting off the airbag - I will eventually put up a post describing how I disarmed and removed the airbag - to replace an R34 steering wheel.
I note differing opinions on the safe handling of airbags, a mechanic friend of mine will not touch them, but panelbeaters replace them regularly.
In my case, I disconnected the battery and did other things for 20 minutes - a delay of 2 minutes is sometimes suggested; I left it longer.
Then, from the side of the steering wheel, I removed one of the two access panels and disconnected the airbag plug.
And now the inevitable disclaimer mate:
This describes my approach. If you choose to follow it and screw it up following this approach, remember - at all times, it's your fault. If you choose to follow it and get a different outcome, that's because you need to know more than what is described here. No responsibility for errors or ommissions. Consider an experienced professional to effect the repair work for you instead.
this is for an R33.
  • 4 months later...
I had an after market steering wheel in my Non-turbo Manual R34. Even though they hooked up a fuse to the airbag connectors to get rid of the Airbag light, it was still on. I replaced the steering wheel with a automatic R34 steering wheel. Even if i connected the Airbag it still flashed. I read all the threads before this to get rid of the light. Instead of pressing the switch on the door i was keep pressing the driver side light switch on the top next to the rear viewing mirror..worship.gif I was so pissed..
Thank god i saw this thread.. Tried it asap..
  • 1 month later...
i had put an aftermarket steering wheel on then swapped it back to the standard one and had airbag light flashing problem
just tried this and it worked without any issues. thanks for the guide!!
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
