Hey guys I got my 100k service done with the kudos kit. I got it done at a well known mechanic in the Wollongong area.
I lowered my idle revs the other day with the plastic screw (r34 gtt). The air flow one I think it is?
It was sitting on around 1100-1200 as that's how I got it.
I lowered it to the reccomennded 650 and since then I can hear a sorting of rubbing sound every now and then like it the timing belt?
Does this sound likely? Should I raise my revs? Take it back to the mechanic? Or is the belt just wearing in??
I've had a couple of 100000 services done and no belt noise.They could of put it on too tight take it back and get them to check,better to be safe than sorry. :D
could me lowering the idle revs done anything??hmm i could be making myself think this but there may be a dip in power.oh really? hmm i like the first comment better then the second haha. i might give him a call.
no not at all.it sounds like a rubbing, you can only hear it on idle.its not a squeak its a rub and it does it over and over while idleing, as if when something turns around its hitting something. if that makes sense. i could probly do a youtube video if need be.
Ive adjusted my timing belt(gates belt) 3 times my self. First time it made a scrubbing kind of sound it was loud. Definitely too tight. Now its just down to a tame whirr which is normal if you are using a gates belt. A gates belt has almost no stretch and no room for tolerance. If you are running the belt too tight it will make noise right throughout the rev range as there is constant strain. Its a pain in the arse loosening it, pretty much everything off again just to get to the damn tensioner.
First time took me about 3 hours, second time to adjust took about 30 mins to pull everything off. I reckon I can do a full timing belt change on an R33 in about 1 hour now.
This is mine:
Most horrible sound my car has ever made. Its gone now and as I said just a faint whirr.
Edited by SargeRX8
simple solution, piss off the gates and get a genuine nissan belt! I had so many dramas with my previous skyline and the gates timing belt. All the mechanics I took it to said that it was normal and to let it 'wear in' and the noise would disappear. 8000km's later and it was still making that humming noise.
I have one of these belts on my own car as well, there are two different gates belts as far as i am aware, the one i have is the "race" version and is blue, it makes a light whirring noise, although your seems louder, or it could just be that my car runs a solid top end and jun cams which are quite loud and it may not be as noticeable.
provided the tension of the belt is ok, i cant see there being a problem, apparently very strong belts, hence the noise, but i wouldn't buy another one, the nismo seems to have the best rap, or genuine
100% belt noise, its definately tighter than it should be. Ill get a video tomorrow of how mine sounds. Its not loud(sometimes when warm it CAN get a little audible) but definately not that noticeable. It is if you stick your head under the bonnet.
And why the hell would you remove it? Adjust the tension, thats it. They are great belts, better than Nissans. Nissan belt is softer so it stretches a tiny bit to give the belt a tiny bit of play room. Get this tensioned right and she will be fine. Its not going to break, its not gonna snap, its not going to kill your engine if its fitted right. Noise is noise, its normal.
Get it adjusted and after a while you wont even notice the tiny whirr. Its inaudible from the cabin.
+1
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
