Hi, Guys, i just done modified on my car, but i found idle sounds a bit problem.
First, when i start engine, the rpm is around 900-1000, but sometimes is quite hard to start engine.
so the problem now is, after runing the car, and it get warm, the rpm start goes up, and stay around 1000 - 1200 during idle, and have sound boh boh boh boh boh when 1200 rpm, when 1000 rpm, everythigns is normal vrommmm idle sounds. i found the MFD there turbo boost, when 1200 rpm and come sound boh boh boh at the same time, the turbo graph show it drop a lot and up a lot, not stable, when 1000 rpm, its stable. is it my turbo problem? is it because the turbo, so the idle sounds like tat? and rpm goes to tat high? i am just using 264 cam.
Can someone please help me? please~ i ask for checking, but the mechanic keep telling me that is mapping problem, not parts problem. untill know still cannot solve this problem, sad...
Regards
Eric
https://www.sau.com.au/forums/topic/368574-idle-problem/
Unlikely to be the turbo, it does nothing at idle. Also not sure it is a mapping problem.
But if I translate your car sounds correctly, I think:
1. vacuum leak somewhere, or
2. lazy fuel pump
3. coil pack failing
4. TPS needs a clean
5. AFM needs a clean
There are DIY's in the Tutorials section.
https://www.sau.com.au/forums/topic/368574-idle-problem/#findComment-5876980
2. lazy fuel pump
Hi, Mate. thank you so your reply.
i did ask my mechanic check , but he say nothings was leaking. i m just change the fuel pump and new okada coil, vacuum is around where? is it intake plenum there? TPS is at where? i dont use AFM now, as i am using F con, and Map sensor.
https://www.sau.com.au/forums/topic/368574-idle-problem/#findComment-5877358
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
