Well its more or less understood that Redline lightweight shockproof is the oil of choice for our aged gearbox, but I would like to know through experience what is the estimated life(km) before changeout is necessary.
I'm going on 20,000kms and I think i'm up for a change
Share your experiences pls.
NB. This is NOT to debate on which oil is better for your gearbox....there are countless threads on that already!
https://www.sau.com.au/forums/topic/368695-redline-lightweight-shockproof/
f**k leaving oil in there for that long. It's cheap enough (the oil) compared to the price of a gearbox. I go on every 20,000km for gearbox and diff oils for daily drivers. Track cars get done every 5,000km just to make sure they are ok
Ford also don't reccomend to service their automatics, people that follow that find the units failing early. IMO the oil is cheap enough, so it doesnt hurt to change it sooner than reccomended
it very well might though, given the way additives work and the fact that you are more then likely cleaning off the nice layer of protection the fluid gives you when you drop it.
You probably aren't allowing the transmission fluid to do its job properly with such frequent change intervals.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
