I have an R32 for sale
List of Mods include:
Pod Filter
Boost Controller
Blitz Blow Off Valve
Proceed Racing Computer
Jasma Exhaust
Lowered Bilstein Suspension
GTR Front Bar
Registered/Road Worthy Certificate
$14,500
Phone 0403 378 236 (QLD)
https://www.sau.com.au/forums/topic/36901-r32-gts-t-14500-au/
i am very interested...i emailed you but no reply
if you get the email can u please reply to it.
otherwise is the vehicle stock besides wat is listed and is it a manual???
how much rego on it
wat year is it
how many km's on the clock??
email me...
[email protected]
or add me to msn if you have it
i am in brisbane and in the market
Jason
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
