Hi, my bf is planning to do an RB25DET silvia conversion. I was wondering if anyone here has any information or experience related to this conversion, or can add anything to his list so far that needs to be considered.
Cheers
SR20 Auto gearbox crossmember.
R33 Engine crossmember with R32 mounts.
Plenum will hit bonnet, chop support from under the bonnet or put spacers in.
FMIC and custom piping.
Aftermarket front and dump pipe.
3" exaust.
The sump will need massaging cause it sits just touching the sway bar.
Cant use the engine fan, need thermo fans prefably two of them.
You can keep the air conditioner.
Can use standard hydraulic lines and power steering lines
Use r32 radiator
Hoses are on the same side as rb25
Aftermarket ecu wolf v4 plus
Can get strut bar, but unsure what size will fit under the bonnet and clear the plenum
Tail shaft need custom to make it fit
R200 mechanical lsd
Throttle cable in SR is longer than rb25det, you can cut the SR cable or use the rb25 one
https://www.sau.com.au/forums/topic/36916-rb25det-silvia-conversion/
instead of chopping the shit out of the bonnet why not have the mounts lowered, which is what my car has had done.
every car i have seen has had to do away with aircon, and if you have a FMIC no chance either i reckon.
show me a strut bar that fits ill buy it!!! custom jobbie i reckon
Cheers
3" exaust.
Use r32 radiator
R200 mechanical lsd
-you need to use 33 mounts with the 33, sits lower and has 2 bolt pattern onto the xmember rather than 32 1 bolt
- you could 'massage' it, might cause problems with oil flow, better to space the sway bar from the body, about 10mm
- would also be good to enlarge/baffle sump while it's out
- might be wrong with the 25, but I think you 32 bottom (if using 32 radiator) and 33 top hose
- front pipe can use rb25 , fits into the s13
- can keep ecu, seen a lot of 25's eating it lately with wolfs but might be just me
that's all I can think of atm
  • 1 month later...
you are going to need a whole new computer, it would help to have a better gear box but if you use just a normal old clutch the clutch will go before the gear box how ever you will have to keep replacing the clutch buts thats better than the gear box. So i recomend you use a rb25 gear box(if she will fit which im not to sure about) a rb20det gear will fit and wil hold and is about 1800 dola cheaper. if i think of anything else ill give you a buz
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
