Looking to buy a GTS-T but the one I am looking at doesnt have one. Is this normal?
Not a deal breaker but had a car that didnt have one and was a pain to drive in the rain.
Also, the passenger door seem to keep on locking by itself automatically in quite a short time. Is that normal too?
Any advice appreciated!
https://www.sau.com.au/forums/topic/369360-a-couple-of-questions-on-r32-gts-t/
you accidently the whole thing.......
what doesn't it have?
The rear wiper is standard on an R32 gts-t
A door automatically locking itself is not normal. It may be part of the alarm system the car has installed... For example I know someone with a mercedes C-class and after you start the car and drive off the doors lock themselves (I assume to reduce chance of car jackin) so I think some aftermarket alarms you can have a similar feature installed.
Ah, cool thanks. Must have been taken out. Hopefully can be fixed as it can be a bitch to drive without one in the rain.
The car doesnt have an alarm on it. Will install one if I do decide to buy it.
there is a product called RAIN X that when applied to your rear windscreen will cause rain water to bead and run off, suggest you get a bottle of that until you get the rear wiper arm back on
