Mine is tapped for both t3 and t4, so if yours is the same then it would also have enough meat on it for this [a lot are already tapped for both, but some stood behind the door and so are only either t3 or t4]. Setting up for both flanges is a simple job, any machine shop could do it in a couple of hours and if you have your own tap and ie set you could do it yoursef pretty easy. They are one of the best flowing manifolds you can use and $500 is a good price..
GL with sale
  • Replies 42
i wouldn't have a clue how it would compare with a 6boost. but car makes 355hp on 15psi with a 3076 which seems to be slightly more then SOME cars with same setups on 16-17psi.
yeah ill leave it wrapped, and include the screamer pipe (its wrapped together with it)
im just still not 100% as a true twin scroll has 123 cylinders into on side of the turbo flange and 456 into the other where this looks different i need to be 100% as if its not a true twin scroll like a 6 boost for instance then it defeats the purpose of me having a twin scroll turbo
I used to own one of these, and there is internal casting that does separate the two sides from each other from memory. A photo of the outlet can confirm.
are you able to put up a pic of the flange i
Even the stock rb25 manifold are divided on the flange but its not a true twin scroll tho
1 1/2 of the flange needs to be from 123 cylinders and the other half the rest
yea its not a true twin judging from the pics if found 1 and 2 merge into the 3rd cylinder where true twin scroll are all separate till they meet the turbo flange
other than thread crap, why not just ask or do some research. The internal diameter of the pipes grow in diameter where the last meet the next, which dont cause an issue. They have been designed to work, and do. If you are not happy with them, dont comment here, its a for sale thread.
im just trying to make sure its twin scroll 100% before i make my purchase from him, I was hoping alot of people with knowledge would comment on this thread, Ive done research and searched alot and from what ive found its not a true twin scroll so it defeats the purpose of having a twin scroll turbo its on the basis of a stock manifold just better flow
all cylinders need to meet into into where the flange is for a twin scroll turbo to be affective im guessing these manifold are designed for a old style t4 flange turbo before twin scroll rear housing where used
It is a twin scroll but does not feature a single merge collector for all runners.
You can't compare a HKS manifold to a simple log style as it sits somewhere between the two types in its design as the runners are blended far better than a basic log. It has shorter runners than a 6Boost which may be helpful for better boost response but who knows how much better?!?!
Last I checked 6Boost are not exactly equal length (although they are close), as Kyle has stated that as long as you are close enough it makes almost no difference.
For a twin scroll to work you need to separate the front 3 cylinders from the rear 3 which the HKS manifold does for both the turbo outlet and wastegate port.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
