HI,
I was wondering which might be a a good exedy to get as my currently clutch is slipping. I dont have 2k to spend right now on a twinplate so i wonder which will do the job.
Heavy Duty Button Kit (NSK-7172HDB) or Sports Organic Kit (NSK-7172SO) or should i look at something else?
Ive just put in the exedy HHHD button clutch and its meant to handle that sort of power but yeah dont go the HD button it wont be enough for 300kw. Just be aware the HHHD is pretty heavy clutch on the foot but thats what I would go with if I was you, the organic is decent aswell just wont last as long as the HHHD at 300kw but then again if its not getting launched that often and sees the odd track day then the organic could be a better choice for a daily drivable clutch.
yeh i dont think they make a HHHD for a gtr..these ones i was looking at the site but not sure which is up to the job if any at all
Heavy Duty Button Kit NSK-7172HDB
Heavy Duty Cushion Button Kit NSK-7172HDCB
Sports Organic Kit NSK-7172SO
Yeah they dont list any of the HHHD for any car on there site so they might have it just, got to ring them. But out of the ones you listed your best bet would be the organic one, but check with exedy for the HHHDB for your car.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
