For Sale:
Skyline R32 GTST
RB20DET
Manual
134k kms (or thereabouts)
Rego til October
Currently has rwc
Coil overs (damper adjustable)
Exhaust
Frount mount intercooler
RB25 Turbo
Race Clutch
18" wheels with near new tyres
GTR Bonnet and grill
Hicas lock out bar
Grooved front brake rotors
Turbo timer
Blitz BOV
Manual boost controller and guage
front strut brace
Just changed timing belt and recently serviced.
Iv not had the car long but i really dont need it now, i walk to work now so it never gets driven like it should. It goes great for an RB20, everything works, reliable car, good paint, lots of potential.
I also just bought 25mm and 20mm spacers which iv not fitted yet but if you want them on and the front lowered a bit i can do that.
I will also get a new sway bar link for the front and the rear hicas rod ends have slight play so il sort them out.
It has a pioneer cd player and speakers, the rear ones are temporary, think the little transfer box at the back is faulty as they work when you hit it or go over a bump. Also the arial has been snipped for some reason, whoever wired it in made a mess basically, but its better than when i got it!
Theres some surface rust coming through underneath which is expected from a 92, but deffinately nothing to worry about.
I will update if i think of anything else, or just give me a shout if theres anything you want to know.
Im in Bundaberg QLD4670
0406483648 - Chris.
$9000 or nearest offers
Thanks!
Pics: It has the gtr grill on now btw, will get new pics.
https://www.sau.com.au/forums/topic/369573-r32-gtst-for-sale/
Price drop $8500!
Just been up to Cairns and back with it and never missed a beat or used oil, very reliable!
Mileage is now 138777kms
Bought another car so it needs to go.
  • 5 months later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
