  • 1 month later...
All i know is that the R32 GTR uses the same clutch as an R33 GTST, as i have an R32 GTR OS Giken clutch in my R33 GTST. There's plenty of R33 GTST owners here who would be looking to upgrade and $1200 is a good price!
it will rattle when you put the clutch in. Makes people think your car is rooted, then you blaze away when the lights go green :(
if it's anything like the OS Giken twin plate it will be awesome!!! Nice and firm, no slippage, but still easy enough to drive. I'd buy that clutch if i was looking to upgrade.
The story behind this is.....
I bought this clutch from Racepace many months ago just before i converted my car to manual as i was promised a series 2 r33 manual box ( pull type clutch ) that had just come up for sale. But at the last minute the sale of this box fell through, and the only other box i could find was a series 1 ( push type ) so therefore i was stuck with this twin plate and not being able to use it :(
Im located in the s.e burbs of melb :D
I would take either clutch. Both good... the rattle is only when you have your foot on the clutch so not that much. Not enought to piss you off... and people who know cars will think "oooh... he's got a twin plate clutch, must be a fast car" :) and people who don't know what the hell it is aren't important!!!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
