Being in Sydney...
SAU Members get discount from Just Jap 101 Bath Rd Kirrawee Ph: 9545.0532
But...
Eugene at "JDM Performance" here on SAU has 1 Nismo GT knob left I think > PM him. Not sure if it's 10mm or 12mm
I just purchased one of these. I am very impressed in its quality and just couldn't go past the price.
(Sorry if link wont work. I had to copy paste the link on my phone).
Manual Gear Knob Shifter NISSAN SKYLINE R32 R33 GTR GTS
Link: http://www.ebay.com.au/itm/Manual-Gear-Knob-Shifter-NISSAN-SKYLINE-R32-R33-GTR-GTS-/380345111116
try nissan. get one from a n15 SSS. nice leather job. not the cheapest though at a few hundred dollars.
when i needed a new gear knob for my 180sx i just went to the wreckers and got one off a standard pulsar. it was just a rubber one but did the job and was comfy and most importantly was a direct fit, not some universal thing with a rubber tube that goes over the thread that usually ends up coming loose.
thanks guys for you valuable input, but i went the ebay option and got a momo short gear knob and the boot for it as well.. does anyone have suggestions to put the gear boot on, i found it difficult to put on, is there a trick too it or does anyone in sydney install these things, putting on the gear knob is a piece of cake but its dramas fitting the gear boot on. i have a nissan skyline r33..
Any help would be grateful....... thanks
The r33 is easy just turn it inside out so you can attach the rubber top part
Then very carefully with a flat head screwdriver pop off the metal fasteners put new boot on all the plastic knobs then put the fasteners back on
Easy
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
