  • Replies 164
Sorry to detract from thread but is the bore 88mm and has block been sleeved?
Both, 88mm without sleeving is not reliable. The bore is either 88 or 89mm. will have to check.
Matt
Matt, If those dumps are the Tomei Series 1's and not cracked I will take them.
they are the larger series, I have Yasky who wants the turbo's and dumps. If I don't hear back by 6pm from him they are yours..then blue_vl_t has next dibs.
Matt
Head also has a Hi Octane rear head drain installed.
RB26 Head $3000 with:
JUN IN EX 264 9.5mm CAMs
Tomei Type B valve springs
New Valve stem seals
1mm Over Valves
Ported by PM engines for max response and hp (the right way..not enlarging the ports)
Deshrouded valves
faced
ARP cam stud kit
OS Giken Adj Cam gears
Black Crinkle coat rocker covers and plenum $450
R34 center emblem
included- valley cover, rocker covers, timing belt cover and plenum
or
With Mines Triple flow cam baffles $550
Edited by BoostdR
are you selling injectors? if so details!
Injectors are sold already.
I would go the Bosch 2200cc with the 11mm adaptor/extender and plug. You just remove the plastic tip. Simon at Morpowa here in SA has a set on the shelf. Only around 165-180$ each. They are much cheaper than ID2000's and in our testing just as good. There are fakes on ebay that use the bosch blanks...these are very bad.
Matt
Xenon Headlights Sold pending payment
evilGTR is second dibs on these if the sale falls through
Kanny is third dibs on these if the sale falls through
Sciro has forth dibs
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
