Hey guys I have 1989 R32 GTS-T for sale in good condition and runs beautifully with no problems at all. It has:
3 Inch exhuast all the way to 5zigen tip, not loud.
ARC side mount intercooler
Tein suspension all round, car is lower and stiffer.
Nismo Cluster (260km) 133***km
Enkei Peak Rims 17x9 Rear 17x8 Front with near new tyres. (Come with one spare for the rear)
Apexi turbo timer and boost gauge.
Kenwood Head Unit.
Adjustable Castor Rod.
Price: $8000 ONO
Contact: 0422106112
It will come with complete stock exhuast system, stock SMIC and stock suspension. Also some spare parts which I will include as well. It includes hicas lock bar kit and rack end. Car is running fine with no problem at all, a/c nice and cold. Always service every 5000km with royal purple oil and genuine nissan oil filter. Diff and gearbox oil changed a few months ago and radiator also flush and filled with new coolant. New bendix brake pads all round with front disc machined Thats all I can remember for now so might miss a few things. The car is very reliable and does not attract cops, I've never been pulled over since I've owned it. Had many cops followed me for awhile then just drive away, drove pass operation taipan a few times before and they just let me go. Rego runs out 8th of Jan 2012 . The car only has a little big of rust in the rear guards. If anyone is interested in buying the car then I'm open for reasonable offers, NOTHING STUPID PLEASE. I'm also interested in a swap for a less value car with atleast 2k my way as I'm buying a bike. Any offers/question please call/text or pm and I'll get back to you asap. cheers
https://www.sau.com.au/forums/topic/369717-1989-type-m-r32-gts-t/
  • 2 months later...
Car is back up for sale, few minor changes to previous info. It now has 138 ***km, all spark plugs have been replaced with NGK Iritop 7 cost $25 each and reconditioned alternator. I'm also interested is a swap for a relatively stock s14 preferably series 2 manual. Just exhuast and suspension mod is alright. I am willing to put a little bit of money on top for the right car but don't low ball me as I am not in a hurry sell/swap. All reasonable offers will be taken seriously. Cheers
Edited by lil_sprinter
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
