hey all started stripping my car got a heap of awesome gear for sale
genuine DMAX silver carbon bonnet suit r33 with aerocatch carbon finish latches
cost me heaps $1400
Red bride stradia with low max rail to suit s and r chassis $1200
pair of bride gias with bride rails came out of r33 $3000
r33 ganadors mirrors motors all work sweet one has been glued as the spring broke $250
r33 black carbon boot with spoiler $750
black te37s 17x9+15 and 18x9.5+22 $2800
defi monster tacho with shift light still got box was in the car for a month $350
PPG 1-4 helical dog box in rb25 housing used for 50ks tops $8000
contact my via pm
got lots more to come
located sa northern suburbs will post at your cost
cheers Andrew
Edited by holes
pics of mirrors sorry bout the delay
one of the springs in the mirror is broken that is all
so one folds back and the other doesnt
also added r33 roof spoiler $120
carbon roof vent $400
thanks Andrew
