Ok guys need a reliable auto electrician to come and have a look at my R33 as i think i might have damaged some electric parts when trying to jump start the car yesterday. I put the cables the wrong way (i know stupid, but hey shit happens) and had some smoke coming from inside the car dashboard. The car does not start at all, it will not even crank, all other electronics work in the car if the key is put in ignition.
So yes anyone can recommend an electrician that will not charge an arm and a leg that could come to my place and have a look at it.
Edited by aky
https://www.sau.com.au/forums/topic/370475-auto-electrician/
Checked the fuses in the boot, they look to be fine. I was thinking of maybe taking the fuses to supercheap and getting a new battery, then replace them all and see how it goes. But would still need an auto electrician in case that does not work.
Went to chk the fuses under the dashboard 2nit, thought to my self lets see if it turns on, surprise surprise it turned on and i took it for a little drive everything looked fine. Parked the car then tried to start it again about 30min later and it will not start, but it at least it makes clicking sounds now. So now i am thinking that it might be the battery that is dead, so will get a new battery tomorrow and will see what happens.
Bought a new battery, put in and it started without any issues. Took it for a drive all good, started the car after 30 min again and its still starting without any problems. So it looks like the battery was the problem after all, the other battery was all watery when i took it out so must have damaged it when trying to jump start it. So relived thought i might have done some serious damage to my car.
  • 4 weeks later...
Nerds lol
I had smoke come from my blinker switch today... Can't be good ay lol
Your relay/blinker might be on its way out. Smoke is never good. What is it? Unless its a fuse melting(which is very unlikely as they designed to blow, unless you put a higher rated 40a fuse in a 5a slot) it is most likely the wire casing melting. This isn't good. One second is nothing, but 3 - 5 seconds is enough to get rid of the plastic and leave bare wire exposed which can cause havoc. My mates ford laser smoked for about 3 seconds, he used the wrong fuse which didn't blow and allowed too much current through. The end result was a bundle of wire with minimal shielding literally melted together. He traded the car in the next day.
I'm pretty handy with electronics, if anyone needs help, I'm near Parramatta and can see what I can do. Ive fixed all issues both electrical and mechanical in all my cars and helped my brother rig up two of his cars.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
