does anyone here knows any website or location in adelaide where I can buy cheap parts for my R34 GTT..parts like intercooler kit..boost controller...GTR or any upgraded fuel pump...rear spoiler...air intake kit...turbo timer...nistune card and things like that...
and if any1 here knows the best person who can install the Mod's here in SA that would be a bonus....
cheers all
https://www.sau.com.au/forums/topic/370716-cheap-skyline-parts/
