Hi Guys
Im selling my turbo and all the bits with it so in a way it will be a complete bolt on kit: it made 250rwkw with a .63 nissan rear housing and stock dump, i haven't had it dyno'ed with the new rear housing and proper dump pipe but it should make more power. condition of the turbo is a bit of shaft play but blows no oil and is in good condition, and i always made sure the car was cooled down before turning off, and the car was serviced regularly with motul oil. the kit is still attached to my car which i have taken off the road.
price is: $1600 obo
Contact: 0403281331, pm , post on the thread
turbo: Garrett 3071r .82 IW rear housing AR/70 front housing
Dump pipe was made by tuggeranong exhaust 3inch
comes with all the water and oil lines and fittings,
also comes with a intake pipe rb25 afm and apexi air filter some more info guys
1 bar actuator
also comes with the stock rb25 manifold with high tensile longer studs and spacers and the heat shield for the manifold,
and i'll i have all the parts off the car in about 3 weeks.
Edited by Greekos
https://www.sau.com.au/forums/topic/371034-rb25-turbo-kit-lowmount/
it used to have the .63 rear housing which i replaced with the genuine Garrett .82 rear this turbo was bought as one of the Garrett 3071r bolt on's for rb25 that came with the Nissan rear housings.
I gather it can use my existing stock lines, no tinkering involved? If i can are you willing to seperate? All i need is the turbo and dump. Reply via text please 0431044680 cheers.
Edited by twistedr33
hi you can try to use the existing lines but whats the point you can buy everything you need an save yourself the hassles feel free to make an offer that's why i put up obo
Update: i haven't been able to remove the gear off the car yet as im running between two jobs atm and trying to clear room in the workshop for the car hopefully this will be off by next week at the latest.
  • 4 weeks later...
the numbers on the tag are as follows kb0116j 700177-5006 it makes it a GT3076R
who ever buys this better hand me a copy of the dyno sheet!
Edited by Greekos
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
