Im wanting to buy a brand new CAS since Ive had enough of going through 3 second hand ones in the past year. Now I found this add on ebay claiming that pretty much anything pre r34 with the exception of the late model r33s have the same CAS. Even though the part number on my original CAS is 23731-02u11 where as the one he is selling is 23731-08u00.
http://www.ebay.com.au/itm/NISSAN-OEM-CRANK-ANGLE-SENSOR-R32-R33-GTR-SKYLINE-GTST-/140565858146?pt=AU_Car_Parts_Accessories&hash=item20ba60c762#ht_718wt_932
Also has anyone got any places to buy them from besides nissan for maybe cheaper and what is the price from nissan if anyone knows.
https://www.sau.com.au/forums/topic/371069-cas-question/
Yes, we don't bother buying second hand units any more. We buy brand new sensors and rebuild the original unit with the new sensor.
So basically you just use your old alloy housing and put a new sensor inside and new bearings - hey presto - new CAS
Costs about $200-$250 depending on a couple of things
https://www.sau.com.au/forums/topic/371069-cas-question/#findComment-5915745
petroject sell them brand new. (in a mitsubishi box) buy the time you pull the old one apart and if the bearinga are ok, its best to just replace with a whole new one. there are a number of differant part numbers as they changed manufacturers from hitachi to mitsubishi..
https://www.sau.com.au/forums/topic/371069-cas-question/#findComment-5917126
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
