Im wanting to buy a brand new CAS since Ive had enough of going through 3 second hand ones in the past year. Now I found this add on ebay claiming that pretty much anything pre r34 with the exception of the late model r33s have the same CAS. Even though the part number on my original CAS is 23731-02u11 where as the one he is selling is 23731-08u00.
http://www.ebay.com.au/itm/NISSAN-OEM-CRANK-ANGLE-SENSOR-R32-R33-GTR-SKYLINE-GTST-/140565858146?pt=AU_Car_Parts_Accessories&hash=item20ba60c762#ht_718wt_932
Also has anyone got any places to buy them from besides nissan for maybe cheaper and what is the price from nissan if anyone knows.
https://www.sau.com.au/forums/topic/371069-cas-question/
Yes, we don't bother buying second hand units any more. We buy brand new sensors and rebuild the original unit with the new sensor.
So basically you just use your old alloy housing and put a new sensor inside and new bearings - hey presto - new CAS
Costs about $200-$250 depending on a couple of things
https://www.sau.com.au/forums/topic/371069-cas-question/#findComment-5915745
petroject sell them brand new. (in a mitsubishi box) buy the time you pull the old one apart and if the bearinga are ok, its best to just replace with a whole new one. there are a number of differant part numbers as they changed manufacturers from hitachi to mitsubishi..
https://www.sau.com.au/forums/topic/371069-cas-question/#findComment-5917126
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
