I have a say.. 'pulsing vibration' in the pedal until the clutch is disengaged
(moving the pedal in and out you can feel it both ways)
and a ticker/rattle from the box that tends to come and go at times, more noticeable when its cold and goes away more when warm.
Does someone know what these mean?
thankkss.
https://www.sau.com.au/forums/topic/371250-clutch-problem/
thankkss.
Is the pulsing vibration there when the engine is stopped as well as running or just one or the other?
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-5917990
It is likely that you either have a broken spring in the clutch plate or diaphram. If the fingers of the clutch cover are uneven, then as the clutch rotates it will be moving the release bearing over the high/low spot on the fingers and hydraulic pulse the slave cylinder up to the master and through the pedal as the recovery port is blocked when the pedal is depressed.
I would check the usual stuff like pivots and slave cylinder first but I'm pretty sure your gearbox is going to need to come out :(
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-5918581
  • 7 months later...
rather than start a new topic i figure id post here. i have the same problem in my r34, its not bad but just enough to annoy me. i replaced the standard clutch with an npc recently so hoping its not a broken spring, but the input shaft did have 0.8mm of lateral movement due to a worn input shaft bearing i believe. is it possible that the movement of the input shaft is causing my vibration, or is it still likely to be something in the clutch broken??
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6264628
did you machine the flywheel?
dont always jump to something major broke.
try thinking of more simple explanations.
if the flywheel was machined, then start looking at the dampening springs in the clutch plate, and go from there.
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6265262
yea i did machine the flywheel, ive got an npc heavy duty organic, so im assuming it has stiffer springs?? and that you would feel more vibration over softer springs right? (i know its trivial, but it makes sense in my head :P) i was really just wondering if the play in the input shaft would be causing my vibration. same idea as the broken spring that as it rotates it causes pluses through the slave which you'd feel in the pedal
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6265481
ive got a spigot bush, but i replaced that as well. also new thrust bearing that came with the clutch. ive also got vibration in the gear lever that i assumed was from the input shaft bearing, hence why i thought it might also be causing the vibration in the clutch.
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6265833
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
