Up for sale are my 19x9.5 +40 (+28 With included 12mm spacers + wheel nuts or +35 with 5mm spacers) Axis Hiro copies.
They sit perfectly flush on a M35 Stagea.
The wheels have been on my car for the past 6 or so months. In perfect condition and never grazed.
Includes Falken tyres. Some wear (see photo).
Price: $999.00 Firm. I can post interstate at buyers expense.
PM or call Chris - 0423 176 774
Here are some photos of the wheels & Tyres:
Cheers.
Chris.
https://www.sau.com.au/forums/topic/371618-fs-19x95-axis-hiro/
I don't suppose you'd know how these would fit on a C34 series 2 manual at all?
I ran Enkei RP03 - 19" x 8.5", +22 and they sat pretty close to flush. I probably had another few mm to the guard edge, so a 9.5", +28 probably wouldn't fit, even without a spacer.
The 9.5" wheel is an extra 13mm wider than the 8.5" from the centre to each side (total 25.4mm). Less 6mm for the offset difference and you're still 6-7mm wider to the outside than my wheels. You'd be cutting it real close!
You'd also have to take into account any rubbing of the tyre on your suspension as the wheel is 13mm wider from the centre to the inside as well.
They'd look good though, especially with wide rubber; it would give a great stance from the rear.
I ran Enkei RP03 - 19" x 8.5", +22 and they sat pretty close to flush. I probably had another few mm to the guard edge, so a 9.5", +28 probably wouldn't fit, even without a spacer. The 9.5" wheel is an extra 13mm wider than the 8.5" from the centre to each side (total 25.4mm). Less 6mm for the offset difference and you're still 6-7mm wider to the outside than my wheels. You'd be cutting it real close! You'd also have to take into account any rubbing of the tyre on your
well. They'd look good though, especially with wide rubber; it would give a great stance from the rear.
Cheers for that. I'm still trying to get my head around what will and won't fit my car. Makes it a little harder having a manual with narrower rear track and not wanting to run spacers.
Hell yeah they'd look good but I can't be arsed with the complications.
Edited by BMX666
Bmx666, after fitting stagered offset wheels to my rs4s. I think we have same front/rear track, it's the auto that has a wider rear end then the front. I bought 18x8 +6 for the rear and +35 for the front then had to fit a 25mm spacer to the front just to fix it. And by my count. These wheels should fit depending on your height, I would do a test fit if you can. 19s would fill the c34 guards so well.
Edited by lilcrash
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
