Hey guys, Here's the story. S13, CA18, T25G, 14psi, Iridium spark plugs gapped to .7
If I drive along in second at about 2800rpm and drop the throttle flat (or if I happen to drop back from 3rd to 2nd and flatten the throttle, the car will mis and splutter from around 2800-3000 rpm up til as late as 32-3400 rpm.
This is much more prevalent when the car is fully up to temp.
I've tried swapping in different coil packs, cleaning the electrodes on the coil packs (no cracks on the existing or addition tested coil packs. Putting fuel into the map there (SAFC) taking fuel out of the map there. Swapped over the coil pack loom.
Plugs are a heat range 6 so a range colder than factory and are only 3000-3500 ks old, about 1000-1500 of those would be track ks. The plug shows white discolouration that correlates to the high rpm usage (this is a track car).
What are your thoughts? I'm thinking of grabbing a cheap set of plugs today to test, but the iridiums were $25 each and are only 3500ks old, the car only makes 165rwkw.
Initially I thought coilpacks or tuning but after trying two sets of coils and putting all the fuel in and taking all the fuel out it doesn't seem to help.
https://www.sau.com.au/forums/topic/371808-misfire-coming-on-boost/
  • Replies 51
Something probably really anoying like; a vacuum leak or a seal somewhere.
Try letting the car idle and listen for air hissing or maybe even trysoap to watch for any bubbles. Also try this maybe with a friend leave it nuetral and rev to build-up pressure.
If not this maybe an oil pick-up issue????
Do you have an aftermarket CPU, get it dynoed...
Good Luck
Im thinking that if it was an air leak then the problem is it's too rich and I took all the fuel out of the map to test and it made no difference.
Car has been on the dyno an has a tuned ecu, I have the safc to monitor and make small ajustments
New plugs gapped to .65 and fresh fuel, still doing it. The fuel filter is only 1000ks old as I considered that.
I'm going to do a bit more testing with the tune as it "feels" like mix related, though I did consider timing?
try 0.5mm gap, if we are required to use them we run all our iridium and plats @ .05mm without power loss.
This.
Had one of these motors at 20+ psi with a disco and could only ever do it at 0.6mm or smaller.
SR eater.
Sorry missed your prior reply.
As a test try crimp your fuel return hose after the FPR. If it works then its your FPR.
Ok re-gapped plugs to .5 noticed that the new plugs are already quite black with carbon , not fuel or oil, a dry build up. Interesting given they are only 50ks old.
Will test drive when the road is dry again, too hard to test in the wet.
Ok weather is finally good enough to go test at .5 will do after work.
Anyone care to explain how crimping the fuel reg hose will help me test?
Whether the FPR is busted and not holding pressure up to your injectors. Crimping will increase fuel pressure to the rail if there isn't enough now.
Ok felt guilty so went for a drive and skipped the last bit of top gear!
A few things to note. Gaps were .5 and I also noticed a plug on top of the air regulator under the throttle body had come off so I fixed that.
Went for a drive and it was only right at the end of the drive that it started to miss a small amount and bog down if I flattened it from 25-2800 onwards. I think it was too cold last night as normally when it does it the water temp has come up to 70 and it only got to 60 last night as it was late and quite cold. Water temp sender is in the rad return hose FYI.
I noticed too that when the car is warmed right up and starts missing it also appears to rev up slower. Wondering if this could be a electrical issue with the cas. I'll take a look at the service manual for the testing procedure and will test the crimped fuel reg next as I only wanted to test one thing at a time.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
