Check Engine light came on today!
I got the error code using the method here:
http://www.skylinesa...ost__p__5616852
ERROR: P0340 Camshaft Position Sensor Circuit Malfunction
Few questions:
1) What the hell?
2) Can the car be driven (short distances)?
3) What the hell?
4) Does anyone know an estimated cost I might be looking at?
5) Anyone have any preferred fixer uppers in the Parramatta region? I did have a list of a few good mechanics but lost it.
ETA: The only things that are 'wrong' when you drive is at a stop there is a small shake to the car.
Edited by LordMidol
https://www.sau.com.au/forums/topic/371867-check-engine-p0340/
Had that error in January this year.
Replaced all three sensors with known working ones, but didn't fix mine.
Mine wouldn't really hold revs properly in startup, shuddered sometimes whilst driving (!!!), generally an unhappy car.
Took it to Nissan who nearly killed my starter motor (why do they never listen to instructions?).
Their Consult 3 stated that it was a "Camshaft Position Sensor Circuit Malfunction Bank 1".
After a small argument with the "tech" about which sensor to use (he was wrong, again), all three were replaced (both cam sensors and the crank sensor) and no change.
Turned out to be one of the prongs in the plug was bent and not contacting properly, it was straightened and haven't had a prob since.
I know, long story... hope you get yours fixed up quick :)
Ahhhh.
Will ring Parramatta Nissan on Monday in that case. Shouldn't be too exxy. Good timing though since my tax return came in 4 days ago.
I'll get some part numbers together. Question: If I specify a part that it requires and they put something else on causing damage are they liable for putting incorrect parts on my car?
Okay. Nissan Parramatta won't fix my car for me. Hmph. Another mechanic will be sought.
Mate if you want to come and try some sensors before you go ahead and by all three your welcome to.....Also try Hornsby Nissan and talk to John.
PM sent with my number
Jetwreck, missed your PM but thanks for the offer - unfortunately it is currently at Hornsby Nissan.
Good news: It is the cam sensors. Bad news: There is additional issues.
Somehow I managed to overfill my oil which is why there is some extra smoke. Nfi how I managed that. Something to do with some wheel bearings as well. Plus a partial service which will set me back $1200.00
Could be worse I suppose. Ohhh, the most awful part was getting the train home. Hornsby to Parramatta should be a whole lot quicker on public transport.
Can't be that bad. I did it for 6 months 10 years ago...LOL
Probably faster during peak hour...maybe >_<
I live 4km from work so haven't caught public transport for over 8 months :P I hate sydney trains.
Not to mention 1 way tickets from hornsby to parramatta are $4.70 each! That's how much I used to spend for a return to the city from parra.
Just reporting back in case someone searches in the future.
Got the car back minus $1240 or so.
From memory the sensors were $180 or so each, the bearing thing was $240 I think and the rest was in labor.
Very friendly guys and the car was left very clean. Had a chat afterwards as one of the guys there own a Stagea as well. We laughed at how I managed to get 6L of extra oil in the car and then stopped laughing when I realised the ramifications of doing so :P It happened when the engine light came on and I asked the GF if it was the oil light and she said I think so. I just dumped 4L in the car on the spot without double checking as I only had 2 hours sleep in 48 hours. Heh.
But yeah, happy with the service. Annoyed at the train I got on. Recommended.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
