hi guys.
selling a rb25det r33 bare block. no oil pump on it. crank still in. has rods and 6 detonated pistons removed from block. had no bearing noises or anything when removed just real smokey lol. want $50 for it
also have a r33 rb25det head from series 1.5 r33. was real good condition. i built another motor on the side and this is the one i removed from the car. want $200 for it. no less.
thanks mates
