  • Replies 52
what grade i can get a mobil1 fully synthetic from here at work for free but its only 5w30
Cool, feel free to throw some free oil my way ;)
Mobil 1 5W-30 with SuperSyn has been improved to provide
even more performance reserve, excellent for
turbo-charged engines that require a SAE 30 or GF-4 engine
oil. Mobil 1 5W-30 is specified for use in Holden Special
Vehicles (HSV) V8 engines with the new General Motors allalloy
motors. Mobil 1 5W-30 is the only oil used in initial fill
and recommended by HSV for the Gen III and IV engines.
This specification is noted on the engine oil cap.
It is also specifically recommended for use in, and is initial fill
for Corvette and Cadillac.
i'll help you with your 30det stuff if you give me some free bottles :P
for one it a rb25det hence why im on SAU more than calaisturbo lol
and like i said i need to be very discreet i dont get it given to me i have to pinch it
Edited by luvpsi
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
