If you think your car is worth over $10K, press Back button now.
I'm after my next mistake car.
happy to spend up to $10K.
what I want is one of the following...
R32 GTST (no f**ked sik drift shitboxes with body kits) - manual, 2 or 4 door, not damaged, with rwc and rego.
R33 GTST (prefer series 2 but will look at 95 models too) - manual, 2 or 4 door, not damaged, with rwc and rego.
R34 GTT manual or auto, 2 door only (assume most would be auto at the cheaper end and needs to be so as I'd be getting it swapped to manual), not damaged with rwc and rego.
prefer light colours (white, silver) but will consider all colours except black (no racist... well... maybe some).
May consider orange at the right price to be able to get it re-sprayed and back under $10K :nyaanyaa:
I'm also happy to pay $10K for the GTR equivelant for the above models.
show me wat u got brah...
https://www.sau.com.au/forums/topic/372688-wtb-sell-me-your-car/
lol.. I will have bought and sold the car by then so it may work out..
but the sequence goes, nissan, subaru, nissan, subaru.
so you might be out of luck
Edit - The Silviaof5weeks doesn't cound as a nissan so we are currently at nissan :domokun:
Edited by GTST
U can have mine for 10. Rwc rego till October. Series 2, 148,000, turbo back exhaust, teins all around, 18s with dish on the rear and 4 newish tyres. Greddy gauges, apexi rsm,
Just done oil change, gearbox oil change, diff fluid.
New 400r copy front bar is about to go on it. And it's white :)
PM sent - '95 r33 gtst
Quality mods - Newish HSD street coilovers/Mines ECU/Exedy heavy duty clutch/turbo back HKS silent power 3"-4" stainless exhaust/supaspark coilpacks/intercooler/pod/HICAS lockbar/choice of a few sets of wheels
Carbon fibre stealth boot spoiler...never boosted over 10 pounds...adjustable/legal GFB bov/heat sheild for pod
  • 3 weeks later...
bump.
would Like R32 or series 2 R33 more so than series 1 skyline..
But will consider them too. :closedeyes:
Id consider selling mine for 10K but would remove some stuff, well worth a look cause its had plenty spent on it and i have proof of its condition eg dyno, compression test
i just put it up for sale just now so take a look if you like.
does it still have a black rear bar and missing petrol cap?
i have the standard bumper to go back on, and the petrol cap is with the panel beaters cause there giving the gtr spoiler a new paint job, picking them up soon
glad i sold my skyline.. cant believe r34's have dropped so much in price that you can get one for sub 10k.. thats insane..
r32's yeah i would believe that.. should get a pretty nice one for 10k.
Although i sold all my nissan imports for stupid prices just to get rid of it.. gl :)
yeah sadly the chance of te previous owners being stig/paul walker wannabe's is very high.. meaning a mangy r32/r33 ..r34 not so much.
good luck mate
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
