95 R33 GTs-t, Silver, series 2 engine. 18k
Mods : Supra front mount
K&N pod ( still have standard box )
Polish catch can
New timmin belt
New water pump
R34 front strutt
New tyres front and rear
Pineapples ( fitted by BMT, most works and tune done by BMT )
Custom front pipe
Apexi N1 catback, 3 inches stainless steel Hi-Flow cat ( still have stock catback system )
R33GTR rear brace
Exeddy button clutch ( still have standard clutch, if i can find it )
Interior : A/F gauge on passenger side ( in dash )
Boost gauge on A pillar
Pro-fect B controller
RACING ECU ( no rev or speed limiter, smooth power curve, still have s2 standard ECU )
4 automatic setting and 1 manual turbo timer ( brand unknow )
Fire exstinguisher mount under driver seat
Alpine deck with 4 ways flip
JBL 6s rear and Clarion 6s front
Exterior : Stealth wing ( still have s2 standard, high wing )
Tiny scoop on top of pod ( cold air flow into pod and turbo )
Overall : Always change oil on time and only use Mobil 1, car running a bit rich still does a 13,6 with bad 60foot time on street tyres ( stock rims too ) and street trims that inclue car jack...spare tyre....ect.
Recomence by BMT to fit Apexi S-AFC to lean fuel out ( save fuel ) therfore gain more power with proper prepare and SAFC will definately ran 13 flat.
Reasone for selling? Family comitment.
Interested? pm for fone numbers, i'm locate in SE melb
https://www.sau.com.au/forums/topic/37273-slow-r33-for-sale/
im interested but the pic didn't work so if u could send me 1 that would b good thanks.
where in melb do u live cause once i have a look at the pic and its good i would like 2 come c it
also a price ?
thanks alot mate cheers
e-mail is : [email protected]
https://www.sau.com.au/forums/topic/37273-slow-r33-for-sale/#findComment-747962
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
